Install Vista doesn't work
userxyz
May 2002
any
2,768
I know, not really a question for this forum, sorry for that.
I try to install vista but I get the following message:
I tried to install on 2 PC's, both gave me the same message...
Anyone knows about this problem ?
It's WIndows Vista Ultimate
Just a guess
Are you upgrading while runnning an existing Windows version? If so, could you boot from the optical disk? I take it PE = Preinstallation Environment, that what you typically see after you boot from the CD to install the OS.
I'd try to boot from CD/DVD.
And I hope you are not expecting to run any siemens software on that PC......as it will not happen...
Jeebs
Not for siemens software, i know. btw, siemens on a XP 64bit doesn't work either.
Booting from DVD doesn't work, it boots, but, no hard disks installed we get ??????
It's a Sony Vaio
Jeebs
Sounds like your Sony may have a SATA hard drive that may require an external driver. This used to be the "press F6 to install a 3rd party driver" message during the initial part of the setup process but with Vista this may be different. If so, download the driver from the Sony web site and put it on a CD/USB drive so that the setup can access it.
I tried to install simatic step7 version 5.1 and 5.3 on my new laptop, but neither worked because both software are incompatable with Windows...
2,707
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
149
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
111
Hello, We have two stand alone FactoryTalk Site Edition clients running. Recently we've had a problem with FactoryTalk Linx on one of them. After...
112
Hi Deal All I had a issue With Rockwell Software try to download HMI but always give error (Unable to the Load Application) then rest the PC but...
119
