integeration of Step7 and Wincc Flexible 2008
Ashiq
Jan 2011
Pakistan
Hi
Dear i am using Step 7 and Wincc Flexible.I want to integerate these two softwares so that i can watch simulation on PC based HMI.I am trying to do so but i am failed.Because i dont know much about Wincc flexible.Please guide me how i can use Wincc.
Hi
Dear Asiq,
Are you useing wincc flexiable with orignal s7 controller or you want only simolate s7 project with wincc flixable. If you have not s7 hardware then you use SimPLC from siemens and you also have wincc flexable runtime licence. You can also simolate your project with winCC.
Dear Asiq,
Dear Zahid Sb i have S7 300 controller hardware Step7 with Floating Licence and WInCC flexible2008 with Floating licence.Now plz guide me.
First instal Step7 (Complete). Then instal WinCC Flex, but choose CUSTOM istallation. When later prompted, select 'Step7 integration' checkbox.
Hello. I need your help. I work at STEP7. There are two CPU 317-2 PN/DP controllers (317-2EK14-0AB0), working on PROFIBUS, as Master (CPU_1) and...
111
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
172
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
157
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
155
Hi all, I am trying to convert RSLogix 5000 program to Step7. I need to bit shift left my array of double integers for tracking the product on...
535
