Intelligent DC drives
rpoet
Jun 2008
New York, NY
536
It seams everyone and their uncle makes a low cost V/Hz drive for 3ph AC motors these days. Does anybody make something comparable for 90VDC motors? Accel, decel, max and min speed, all programmed digitally instead of via trim pots. It seems that DC drives are stuck in the analog dark ages. Is it really so hard to build a DC drive with a little intelligence, or is there simply not the demand?
-rpoet
-rpoet
Mostly no demand, but they are out there. The problem is that the old analog SCR drives are so darned cheap and most people don't really need a lot of whoop-tee-doo features for things that still use little 90VDC motors, so there is not a lot of incentive to create a digital-for-digital-sake DC drive.
That said, Dart Controls makes a low cost digital DC drive. Bardac / Sprint and Seco (Bronco drives, now part of Danaher Motion) too.
I guess I hadn't realized that Dart had come into the digital world. I do agree; the things 90V motors are good for don't often need fancy control. It was mostly an academic question, since I hadn't really seen too much intelligence in the DC world.
Thanks!
-rpoet
-rpoet
Copley?
http://www.copleycontrols.com/index.html
I just graduated as a mechanical engineering student, and started this new job a controls specialist with a company in my area. My coworker has me...
980
MELSEQ "intelligent modules" configuration, programmatically resetting the CPU Hello. This is for the Mitsubishi experts, and thanks in advance...
1,077
Haven't done much with soft starts, more-so VFDs' in my time. Looking at replacing 3 x 37KW (415 V 50 Hz) star-delta starters with soft starters...
2,889
We have an old punch press machine. Many years ago (probably around 1990) a machine builder called Steelcase Inc (currently not in machinebuilder...
1,563
Hi, I have a situation at my plant, where I need to interface my existing PLC with some field devices Via Modbus Interface. I can not change the...
22
5,179
