intelligent I/O
The term "Intelligent I/O" is used by many suppliers in a variety of ways. There isn't a single definition, but in general it indictes that functions in addition to the basics. In general conventional I/O just reads the status of a signal (ON or OFF for discrete) or the value of a process signal (12 mA = 2048 with analog for example). Remote I/O is the same, but includes a communications link for reading the status or value from a device in a different physical location.
With intelligent I/O some kind of function adds to remote I/O capabilities. This may be just diagnostics to indicate bad modules or loss of signal. It may add some logic capabilities such as limit alarms turning on an output when an analog value drops beow a set point, or it may allow interlocks, so that for example a given output may only turn on if two designated inputs are also turned on. At teh extreme, a micro PLC networked to a master may be considered an extreme example of intelligent I/O.
Intelligent I/O is often used with PC based control or SCADA systems, since the PC doesn't have built in I/O capabilites. It is also used where failure of the PC, master controller failure, or communications latency can cause damage or personnel hazards. For example, it could be used in a pump station connected by radio telemtry to a SCADA PC. You wouldn't want the pump damaged if the wet well runs low, so you use the local intelligent I/O to turn off the pump on a low level float switch signal even if the SCADA master says it should run. That way, the time elapsed between the float switch tripping and the PC getting the signal and deciding to turn off the pump and then sending the signal back to turn off the pump won't let the pump run dry.
I just graduated as a mechanical engineering student, and started this new job a controls specialist with a company in my area. My coworker has me...
978
MELSEQ "intelligent modules" configuration, programmatically resetting the CPU Hello. This is for the Mitsubishi experts, and thanks in advance...
1,073
Haven't done much with soft starts, more-so VFDs' in my time. Looking at replacing 3 x 37KW (415 V 50 Hz) star-delta starters with soft starters...
2,888
We have an old punch press machine. Many years ago (probably around 1990) a machine builder called Steelcase Inc (currently not in machinebuilder...
1,563
Hi, I have a situation at my plant, where I need to interface my existing PLC with some field devices Via Modbus Interface. I can not change the...
22
5,179
