Interface with Barcode Reader
ajmoyer85
Feb 2010
Minnesota
I am trying to send native commands from Compact Logix L32E over ethernet to a keyence SR600 series barcode reader. This reader does not except ethernet/ip. How do I do this???
Welcome to the Forum.
I don't believe you will be able to use Ethernet for integrating the barcode scanner; it looks like the scanner's port is used exclusively for user software access.
The commonly used procedure for this type of integration uses ASCII over the CPU's on-board RS232 port or using a 1769 backplane installed 1769-ASCII communications module.
Depending of the model, follow the instruction manuals within:
http://www-search.keyence.com/us/enus/downloadpro/search.x?mode=ma&f=DO_GROUPID_sm%3A26-2109%09DO_TYPEID_sm%3A26-2108%09DO_SUBTYPEID_sm%3A26-2106%09DO_SALESSERIESID_sm%3AWS_SR47624&p=/products/vision/barcode/sr-600/index.jsp
This reader is able to support ethernet commands using N-L1. I already do this with a wago 750-841 and would like to do the same with an allen bradley PAC.
In my view, search for google to find more barcode reader guide is necessary, you can gain more useful information by doing so, then, try to find a suitable one to help you solve your problem, am I right?
please guide me to interface sick clv620 bar code scanner with omron cj2m cpu31 plc
1,813
Hi there, I'd like to integrate a barcode printer /reader into my systems. When customer pays I want to issue a barcode printed reciept...
6,428
Can anybody guide on how to interface a Barcode signal into a PLC. Is it through RS232 communication?
3,706
Hello , I want to Interface AB 1200 PLC with Barcode scanner .
2,146
for one of my project i want to connect plc with barcode scanner to read the data from scanner. plc am using is mitsubishi with ehternet port do...
1,696
