Interfacing AB Micrologix & Siemens Protool
lucifer
Nov 2003
52
hello there,
can someone tell me how to interface allen bradley Micrologix 1500 LRP series C PLC with Siemens Protool for runtime data exchange......i have gone through 2 optins....
1. Prosoft's protocol convertor
2. installin rockwell's driver on the hos PC
but none of it i've seen implemented......if anyone of u can enlighten me on this issue or any other means of doin it....
thanx
Hello, Lucifer;
Protool/Pro has integrated DF1 and DH-485 drivers that should allow you to connect directly to the comm ports of Allen-Bradley PLCs, including the Micrologix family, either through a standard RS-232 cable, or a RS-485 network.
Open the Protool help files and search for "Configuration", and look for Allen-Bradley topics. You should have no trouble finding adequate data.
Hope this helps,
Daniel Chartier
Hello Experts !! Greetings, Hope you all doing great !! I want to Interface Multiple (Upto 10 ) Barcode Scanner Serially to PLC Micrologix 1400...
2,676
I was wondering if it was possible to take allen bradley micrologix plc's and interface it to ge cimplicity hmi's. If it is possible what do I...
2,041
Hi there, I am developing an application which requires interfacing to a PLC.I will be producing quite a number of the same machine each year. I...
1,580
Have anyone done an data exchange between a Micrologix 1000 and a S7-3xx ? I guess hardware-wise is possible to use a DF1-to-Ethernet to put the...
3,524
Afternoon All, I am working on a Project to bring I/O from a MicroLogix 1200(1762-L40AWA) to a SLC 5/05 (1747-L551)NOTE all of this work is...
2,455
