Interfacing connectors
Apr 2002
Just a bit northeast of nowhere
1,117
Greetings!
I'm working on a project using Beckhoff IP67 remote IO, which is only available (as a discrete output) in PNP DC. I need to connect this to a 120 VAC signal (<100mA).
Now, I already know - relay. But the point of using IP67 remote IO is to reduce wiring and enclosure space, so I'm trying to find something special.
I've already found a module that plugs into an M12 socket and can convert PNP signals to NPN signals. Place it in-line with the switch.
What I'm trying to find is an output adapter with a dry contact, in the form factor of an M12 field-assembly plug.
Anybody know where to find such an animal?
TM
Sorry I can't help you with the dry contact animal, but I AM interested in the PNP to NPN converter you mentioned! Who makes this?
-Eric
I have a Cognex Insight 2000-130 camera that I'm trying to get talking to my PLC. Both are connected to the same router via Ethernet. Thus far...
1,251
Hi, I am picking up a project started by a predecessor who is now out of contact. It is a Siemens S7-1515F PLC system - but the query is how you...
757
Hi everyone, I've got to interface 4 x Mitsubishi Q series PLC's with an Allen Bradley Compact Logix PLC using a Red Lion Data Station DSPLE000...
511
hello i want to read temperature data from Masibus UT94 temperature transmitter which is giving data on RS485 port. i have assigned ID:-30 and...
1,065
Hello I am very familiar with ladder logic and PLC programming, however I am new to Allen Bradley, ethernetIP, and interfacing measurement...
1,035
