Interposing Relays
well?...
  • Never will, never have, I hate relays
    Votes: 0 0.0%
  • If there is a need and only then, but I try to never use them
    Votes: 25 49.0%
  • What’s a relay?
    Votes: 2 3.9%
  • Always
    Votes: 7 13.7%
  • Always try to, if I can
    Votes: 8 15.7%
  • Only if I’m mixing voltages
    Votes: 9 17.6%
  • Lets remove all plc’s and replace them with relays
    Votes: 0 0.0%
  • I support relay logic and never want to stop using it
    Votes: 1 2.0%
  • Don’t care
    Votes: 1 2.0%
  • Total voters
    51
  • Poll closed .
geniusintraining said:
Derived from.... http://www.plctalk.net/qanda/showthread.php?t=31776
there have been a lot of comments on that thread... but just to see how many disagree with the people that do it the correct way ;)
I hope I covered them all...
Edit: I made the second one from the bottom for my friend Mickey :D
Thanks, I do support relay logic. But thats not what I said in the other thread. My vote is "Always" install interposing relays.
The PLC is used to control the output relays and to read the status of the input relays. ( thus interposing or slave relays)
My main reason is isolation. ( in and out)
I agree with everything JesterMP says and disagree with most everything Gerry and Panic Mode said.
So there.
...and Hakutsuru said...
I don't think I've ever seen a poll in this forum. I'm sure the results, as with any opinion poll, can be manipulated according to how the question is asked. I think most of us are smart enough to realize that, and maybe thats why there aren't many done.
-jeff
I guess he hasn't been paying attention.
i stand by what i said, different applications have different needs. i am not declaring war on
interposing relays, i use them when and where they are needed or present good solution.
but doing same thing over and over (and just for the heck of it, not because it's needed or justified...)
reminds me of one member's signature... (poll starter?)
Just wondering what other folks have used on their digital output loads when using this digital output module. There will be a number of...
1,077
My apologies for revisiting a subject that has probably been beaten to death BUT some input please....I have had problems with PLC outputs failing...
18
5,715
I've read two or three post on this PLC Talk where it was stated that 24 VDC powered relays were preferred for interposing relays. A few...
23
12,221
What is the use of Interposing relay, Is it only required for solenoid Valves because of different requirement Voltage (PLC is restricted to...
10,434
Hi all, I have a contractor trying to convince me to install 'interposing relays' on the output of PLC cards. The supposed benefits being 1)...
30
14,212
