Intouch 10.0 and Win7?
NetNathan
Nov 2011
Corona, CA
2,200
Anyone running Intouch 10.0 SP2 on Win7?
Wonderware Compatibility Matrix says Win7 starts at 10.1, but I have found loopholes in their matrix.
Tha also said that Intouch 7.1 would not run in WinXP, but it does.
No. The oldest version that I have ever installed is 10.1 on Win 7. That said, "will it run?" is not exactly the same question as "is it fully compliant?" For instance, you'd have trouble finding your InTouch application folder with Version 7.1 Application Manager running on XP, but there are a couple of easy work-arounds for this problem. It has to do with how XP handled the old 8.3 filename convention. Still, it is a valid OS compatibility issue. XP also shipped with a software firewall, turned on by default, that affected Version 7.1 communications, but there are easy work-arounds for this issue as well.
I would think that any version of InTouch that ran on Vista should be able to run on Win 7, but I'm not really sure of that.
I have just set up a V10.0 on Windows 7 SP1 and although I had issues while installing, due to not quite getting the need to establish a windows account for InTouch (do not the change or expire the password, InTouch will stop working correctly - it said!), I have got it running.
Indeed I have setup Virtual Machines to run V7.0 to V9.5 on Windows XP and V10.0 to 2014 on Windows 7 - I need this as I have 29 applications on site in the various versions, with Win NT forward to Win 7...I need to be able to support them before we start to migrate to 2014 for them all..
What version of SQL Server are you using with Intouch 10.0 under Win7?
I am loading Intouch 10.1 on a test machine with Windows 7 and I have everything working except for Alarm Printer. The standard .bat file we use...
5,382
I am trying to set this up on a win7 machine. I have it working well on a XP machine, but canny get the same setting to work on a win7 machine. I...
2,239
I am currently working on converting an Object-based ArchestrA System Platform HMI to a Tag-based InTouch HMI. Currently, the I/O is linked...
18
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
87
