Intouch 9.5 Runtime Language Switch Questions
andrzejplo
Mar 2006
Kraków
22
Hello,
I have a question about Runtime Language Switch in Intouch 9.5.
1.How to change language in Alarm Text in new Intouch 9.5 version? Alarms are integrated with an application so I also want to change their texts.
2.I read in this presentation that new version has possibility of "All Static Text Can Be Switched". It means that I have a text like "Text1" and and a tags named Pump_On_OFF and when Pum_ON_OFF is force to logical 1 in a filed Text1 text "ON" will appear and when tag Pump_ON_OFF will switch to 0 than text "ON" will automaticaly changed to "OFF" . Can I wrote this logic in Script and these texts "ON" "OFF" will also be imported into this XML "LanguageSwitch File?? How can I do something like this?
3.I have 100 Tanks (the same) and I want to use Intouch SuperTag method as a simply way of doing indications popup for each Tank. I will do one Popup with this indications and I want to include headline (Like "Tank 1") depends on which Tank I choose. If I choose Tank33 I want to send Headling or Text "Tank 33" Action Script code is mentioned below: 'Here I Use Super Tags and I send It to the window with indication
STF.Name = Tank1.Name; ShowTopLeftAt( "Tank_Temperat", 500, 210 );
'Here I open my Window with indication. 'How to send a Headling for exaplme " Tank 1 indication" 'which will be transleted with this Runtime language switch
How does this Runtime Language Switch works witch Scripts Is this generaly possible?
If Yes how to do this in Intouch 9.5?? It is very important in using Super Tag Method in my application which I will do in 9.5 version.
The Runtime Language Switch is for static strings. If you want to change the language of your tags, like the alarm text or On and Off messages you would need to do so in a script. You could create a script that is called whenever the $Language tag changes. Then you would use the script to change the Dot fields for your tags.
In regards to your Popup, I would omit the Title from the popup window and put a message tag to use for the heading. Then I would make the message display the tag STF.comment
Wizard of Intouch, I summon you. I'm having problem when publishing the runtime application from my workstation to the runtime panel. My...
775
Could anyone please provide script to show popup on active screen ..? I have written windows script to show on current screen in " While showing...
884
Hello all, I have programmed a script in InTouch which will increment a value (lets say "tag1") from 0 to 10000 within a given interval. This...
18
5,928
I used a few built-in SA symbols, and by default, their color is grey... so I loaded a new element style to make them look better. However, no...
1,512
I'm upgrading a panel mounted PC in the field. I'm going to install InTouch runtime and just copy and paste the LIC files from the old PC.. Is...
4,600
