Intouch Windowviewer only displaying on one screen
BKoch
May 2018
Alabama
32
I am attempting to make a multiscreen application but after following multiple pieces of advice online it remains on one screen.
One thing to note is that the viewport is big enough for a scroll bar but the actual window stops at the end of the first screen.
I have updated win.ini to read:
Code:
; for 16-bit app support
[fonts]
[extensions]
[mci extensions]
[files]
[Mail]
MAPI=1
[Intouch]
MultiScreen=1
MultiScreenWidth=1920
MultiScreenHeight=1080
This file is replicated in
C:\Users\<myuser>\WINDOWS
C:\Users\<myuser>\AppData\Local\Wonderware
C:\WINDOWS
I have also tried changing MultiScreenWidth to 3840 but nothing changes. I have also tried each of the dynamic resolution settings under "Node Properties" but the most they do is stretch the graphics on the one screen.
I am really stuck here and would appreciate any advice :unsure:
Welcome to the forum.
As far as I know, Wonderware will not allow multiple screens in the application. My co worker has been doing wonderware for years and has not been able to accomplish this.
someone may have a solution, if so please chime in, we need this as well.
james
Something in Windows 10 broke Multi-monitor support in InTouch. You should still be able to open a window on a second monitor by defining it in the location of the second monitor. I don't recall if it has to be a pop-up window. I'm pretty sure you can't just use a ShowAt function to open a replace window on a second monitor any longer.
That's a bummer, but I guess I'll have to work around it. You're correct about the popup windows, that's what I've been using on my second screen so far.
I just dislike how if you show a graphic on the pop-up window and then click somewhere outside of the graphic, the window takes priority and brings itself to the front, hiding the graphic. I'll have to figure out a way to keep it in the back o_O (or keep the graphic in the front)
Thanks for letting me know about the Windows 10 problem, at least now I know I need a different approach.
There are several tech notes on this subject. I was able to to do this on several systems Server 2012 R2/Windows 7. From what I can recall there are two ways to do it. The one that was the most successful for me was having the video card treat the two monitors as one. Then it was just sizing the windows or opening several windows on different x axis. It was not easy and I am not sure on windows 10.
Edit Legacy tech note 811
I actually just found a solution to my issue! I had previously thought my computer was not capable of treating 2 monitors as 1 but looking into that more I found that my Intel graphics card has a "collage" mode which accomplishes this.
I can now have 2 different overlay windows that act exactly as I needed!
(y)
Hi everyone, I am on application built on Wonderware Intouch 2017 Update 2. I am not the designer of this app, just have to maintain it. The...
1,941
Hello everyone. Please help me to solve this issue with Intouch 2017. I get notice “ Failed to open Intouch Application” when I try to open my...
4,760
We have a project where have updated the Tricon logic with some alarms and trips. The InTouch Window Viewer is not updating it's alarm list with...
2,802
Now, I can execute a application by click the Runtime button in InTouch, but how can I switch to another application in Windowviewer when the...
2,196
Hello, AVEVA OI system drivers such as ABCIP and MBTCP provide a discrete register called $SYS$STATUS, which can be tied to a Discrete tag in...
23
