ip setting for T2N
mostafah
Apr 2007
tehran-iran
26
hello every one!
i have a pu235n(T2N CPU),i can program it through serial port, but i cant connect it via ethernet.how can i set its ip?i found this program in its manual:
This program is executed by turning on the R0502 A contact.
Parameters: 12544:3100H, 00018:0012H
29061:7185H, 02658:0A62H
|R0502 R0602 |
1|-| |-----------------------------------------------------------( )--|
| /* Parameter setup request */
|R0602 |
2|-| |-+[ 12544 MOV RW000][ 00018 MOV RW001]--------------------------|
| | /* Designates the module and sets the CMD number. */
| +[ 29061 MOV RW002][ 02658 MOV RW003][ 01025 MOV RW004]--------|
| | /* Sets the IP address, Port number. */
| +[RW000 SEND RW010][ RST R0502]--------------------------------|
| /* Sets the request. */
but it did not work. can any body help me?
mosrafa havaeji​
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
882
SELECTED NEW FILE SELECTED PROCESSOR TYPE SELECTED I/O CONFIGURATIONS IM UNABLE TO CONFIGURE MY I/O’S. I HAVE A PAPER COPY OF A PROGRAM AND I...
89
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
243
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
92
Hello. I am trying to use a Prosoft AN-X4 to improve the communications for a new panelview plus 7. This is going from a SLC-500 through DH+ to a...
300
