Is cable interchangeable
graemeian
Feb 2012
NC
I have a PC connected to an Omron CQM1 and it works properly. I also have a CJ1M. Will the same rs232 communications cable work for both?
What is the part number of the cable you are using? I use a CN226 for the CJ1M and a CIF02 for the CQM1
The CIF02 is a 20 pin connector (two rows of 10) the CN226 looks like a mini HDMI conector
Although for the CQM1, I have both a CQM1-CIF02 and an RS232 modified M/F cable. I have never needed to take the CQM1-CIF02 out of the package.
Now for the CJ1M, can I talk through the RS232 or must I talk through the peripheral?
Not sure but you should be able to give it a try... what is the part number of the modified cable you want to try?
I just tried a CN220 and it acts strange, I went online with the CJ1M using the CN226 but when I tried the CN220 and the DB9 port it acts like its going online then gets bumped off.... the DB9 port I think is configurable so that maybe the issue, it sees the PLC but can not upload :unsure: just a guess
It maybe better if you just buy a CN226 https://www.plccable.com/omron-plc-cable-usb-cs1w-cn226-cs1wcn226-usb-version/
There are a few members that are very good with Omron and they may chime in....
You can connect to the Serial Port for programming by setting DIPSWITCH 5 to OFF and using Custom Settings for the Host Link Port tab in the PLC. Make sure you have the correct pinouts for the serial cable.
I am considering using a "magnetic cable tie mount" like this one: https://www.grainger.com/product/MAG-MATE-Magnet-with-Zip-Tie-Holder-49M018 It...
102
I have an existing machine that we are adding some functionality. Currently every cable such as a cable going out to a 4-20 psi sensor for example...
255
Hello everybody, I believe that I will find experts here who have already solved a similar topic. I need to calculate the length of the...
354
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
135
Can anyone recommend a universal USB to IrDA cable for interfacing with power meters? I see a lot of generic units but hoping someone has...
66
