is it possible to communicate between two CP-317f through cp 343?
anubdawson
May 2009
Bangalore
Is it possible to communicate between two siemens CP-317F PLCs by using cp 343?How to configure the hardware??i want to handshake the signals between two plcs.
Yes, it is possible.
But why spend money on two CP343's if it is perfectly possible to communicate through the programming ports? Why do you need CP343? How much data are you exchanging, what type is the data and how often do you need to communicate?
Based on that info it might well be you'll be saving major bucks and yet obtain the goal you're aiming at.
Kind regards,
If the "handshake signals" are critical in importance and timing, then a reliable solution would be to setup both PLCs as DP masters for one DP/DP coupler, and then exchange the signals that way. Will also be less expensive than adding a CP343-1's to each PLC.
Currently I'm working in a project, and there is a problem, we need to show what is going on with the CR30 through an app developed in VB.NET, we...
615
Hello Friends I have several machines with different ip range everyone, according with the image. The PLC's are Micrologix 1100/1400 with...
2,195
I've always connected with DH+ PanelViews through a CLX gateway, but I am working on one today that is connected to a SLC 5/04. I'm connected to...
1,475
Hello. This is my first time to post my question. So nice to meet you and although it is late, happy new year. Anyway i gonna stuck on my...
1,717
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
242
