Is there a "good" way to convert from serial radio to ethernet PLC?
defcon.klaxon
Feb 2015
Far NorCal
616
Hey guys,
I have a client with old SCADA hardware (Scadapacks from back when they only had d-sub serial connectors) that wants to upgrade. They have several remote sites (water treatment) and they run TeleDesign TS4000 radios (unlicensed VHF, ~150MHz). I prefer to spec Allen Bradley (CompactLogix) and the client is fine with that, but the issue I wonder about is getting radios working. I'd love to stick with the radios they currently have because they work well and I like TS4000s. Unfortunately the TS4000 only comes with a serial interface. I could change the radios out to something with a native ethernet port, but I would really love to stick with TS4000s if at all possible. So I'm wondering if there's some product out there that can take an ethernet connection, "convert" it to serial, and then "revert" back to ethernet on the other side. I'm checking Google but it seems like most solutions are meant to connect a serial device to a LAN, not the other way around. Or maybe you guys can suggest another radio that is as reliable as the TS4000 but has ethernet native?
The digi one IAP may work as an Ethernet to serial converter in your application. Also I was told that the 5069 series compact Logix plc either has or will soon have a Serial Port add-on module. I was told that this new module will support modbus natively. The micrologix 1400 might also be a good fit for your application depending on the io counts
I will take a look, thank!
That's interesting. I wonder how they'll support modbus natively if modbus addresses are 16 bits and everything in Logix is 32 bits; obviously floats in modbus are 32 bits but you have to manually remember not to step on your own feet, so to speak. What I really love about ethernet/ip is that I can just pack/unpack everything in arrays and use a Message to send it. Super easy, which is why I love AB compared to Scadapack. But we'll have to see.
I'll take a look at this also!
you could use a red lion datastation to convert from ethernet to serial.. but honestly, you are going the wrong way with this. I would just change the radios out to ethernet and be done with it.
What's going to be on the "Central" station; a SCADA computer, or a central PLC type controller ?
I agree, this is a challenge. I don't think I've ever seen it done.
I would call Real-Time Automation in Wisconsin, and ask if their "515 RTA ENI" device has a DF1 -> IP address routing table in it.
Even if you have to buy one to test it out, it's probably worth it if you have any 1761-NET-ENI devices in the field, as the RTA device is a very good future replacement for the Net-ENI.
Maybe I am old fashion, but I am really not to fund of Ethernet in a control environment.
I would stick with the serial all the way true, in my world it is rock solid :)
If they are a water utility they should consider the benefits of DNP3. Works over serial, Ethernet, is routable and data logging is part of the protocol. So no loss of compliance data if your link goes down.
The SCADAPack 575 runs Unity Pro style logic. the software is called Remote Connect and is free. Have a chat to your Schneider Rep.
1000 times better than the old 300 series stuff!
Found an awesome point of sale for $500. It sends an ascii string when a product is sold. Need to convert this into a number between 0 and 255 or...
2,285
Hi everyone, In my coming project we have to convert Serial RS422 RK512/3964(R)protocol to Profibus DP Slave(Baud Rate 1.5 Mbps).Any one who...
2,432
Hi! What is the way to convert the code from the Codesys code to the Tia Portal? Regards, WK
87
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
128
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
387
