Is there a way to log to a DBF file with factorytalkview SE
billyjb2000
Jun 2012
canada
I just converted an existing application from RSView32 to FactoryTalkView SE.
In RSView32, the Datalog was made in a *.DBF file.
There was software that generated a report in Excel from the *.DBF file.
Now, FactoryTalkView SE logs in *.DAT. It no longer seems to support *.DBF files.
I found a way to do it in Rockwell's KnowledgeBase that I cannot implement.
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/69931/loc/en_US
Has anyone ever done this?
The directions they give are ok. But they miss a few things. I walked through this all on one computer. So I wasn't copying from one machine to another. Couple things I did.
1. I created a "database" folder where I stored everything. Just made sense to me to have everything in one place. They don't indicate where to store anything. I think that was especially helpful for step #7 to store the DBF files in a specific location so I could find them when I needed to.
2. My version of Access doesn't create the .MDB format anymore. So I had to do a Save As and tell it to save as the MDB format. I used the 2002 format option.
3. On step #10 you need to click the browse button net to each table to select the DBF versions of those tables.
Once I figured out those things, it all worked and I was logging into the DBF database.
OG
Hi, I have same system connected to 2 PC's running RSView32 SE (old)and another with Factorytalk SE (new). I next few months old one will be...
1,516
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
30
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
120
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
131
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,159
