Issues Communicating with PLC
plctechweg
Sep 2020
Fort Wayne
I'm not sure exactly what is going on. I am attempting to communicate with my plc and my HMI, but I am unable to go online with either one. I am using a virtual box program to access studio 5000 and rslinx classic. I have my ip address set correctly and my subnet is correct as well. But for some reason I am unable to ping my processor or go online with my plc. When I attempt a ping it just says "destination host unreachable", and in rslinx I just have red x's on all my available processors.
What Network mode do you have configured on your virtualbox? Where in relation to that is your HMI/PLC/host machine.
I don't use virtualbox, but in general you want to have it setup to either NAT from the guest/host to the external network or set it up in Bridged mode.
Hello all, I seem to repeatedly run into troubles downloading from Crimson 3.0 into a G315 HMI. Before the holidays, things seemed to work...
1,216
Earlier today I started trying to use a Micrologix 1100 unit that had previously been in use elsewhere in our plant. Upon powering the unit up...
11,115
I am having a problem with a compact logix L32E showing values on the display of a Panle View plus 1000. My graphics are all there on my touch...
9,382
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
173
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
160
