kepserver problem after connection loss!
hassanayoub85
May 2013
Texas
33
Dear,
I developed an OPC Systems.Net C# application for him, allowing me to control a plc remotely.
Everything are going right, however, just small thing.
When I click on my application on a button which setting a tag to true, the tag on PLC is going true, and the lamp turns on. which is great, when I release the button, the tag going false,and on PLC same thing, and Lamp turn off.
When the connection is lost, Ethernet connection, I configured the PLC to turn off all lamps. and this i going right too.
However, after the connection come back, the lamp lamp turn on a bit then turn off.
I am diagnosing the issue myself, and I found that the last value of the tag on kepserver before connection lost (true), is sent to the PLC after connection comeback, while the tag i set to false during this connection loss.
Conclusion:
I want to (when there i connection loss, all tags reset to default value, or, use the last value after connection lost, not last value before connection loss.
How to solve this issue?
Hi! I have a GEFANUC Versamax PLC and i want to conect it with WINCC FLEXIBLE 2007, im using KEPSERVER and i dont have problems reading the data...
8,169
when i am trying to change the values of a sample program which is downloaded from allenbradley website i am facing one problem that i am not able...
5,255
Hi all, I was trying to communicate FX3GE PLC with KEPServer / Kepware via UDP protocol but did not succeed. Does anybody has any solution or...
1,079
Hello PLCtalk community, I force to 1 bits in System Platform that are read by KepServer, and for some reason other bits are going down to zero...
3,474
I have nuisance alarm that comes and goes. Doesn't seem to stay longer for a few seconds, is there any way I can somehow add a time delay or...
1,512
