Kepserver simulation
sayahan2003
Jun 2006
Calgary
185
Hi Everyone,
I am going to make a Modbus TCP link between Kepserver and an analyzer, but the analyzer is not available yet. Is there any software that I can use it as a simulator to communicate with Kepserver?
Two ways come to mind:
https://sourceforge.net/projects/easymodbustcp/
The latest package comes with a simulator for testing. This would work would with the Kepserver.
http://www.automationdirect.com/adc/Overview/Catalog/Software_Products/Programmable_Controller_Software/Do-more_PLC_Programming_Software
Automation Direct Do-More Designer Software. This PLC software comes with a simulator. I have used Modbus TCP to communicate to it from other packages. Kepserver should be no exception.
http://support.automationdirect.com/products/domore.html
Hope this helps you out,
Thanks Chris,
So, I configured the Kepserver as it shown in the attached photo. Now, what is the next step? How I can communicate with the simulator?
sayahan2003
is the simulator on the same PC?
If so, set Channel 1 to Modbus TCP/IP Ethernet
Set AIT-4140 under general as Modbus and set the ID to <localhost>.1
Check the port is 502 (under the Ethernet tab). that should get you going
you will need to run the OPC Quick client to see any values
The OPC quick Client is connected to Kepware, its showing good values for the data. what modbus address are your tags set to?
Even if I don't open the simulator, it is showing "good" value! The address for AIT-4140 in kepserver is is register 40001. I can not read or write to this register using simulator.
OK
lets get Kepware communicating first.
I have kepware on a different machine so I use an IP address, if you haven't already you could try the loop back address of <127.0.0.0> or any actual IP address on the machine.
This is mine:
This works.
Now Kepware will not connect until it has a client, so run the Quick Client and it will connect.
Hi all, I was trying to communicate FX3GE PLC with KEPServer / Kepware via UDP protocol but did not succeed. Does anybody has any solution or...
1,065
Hello PLCtalk community, I force to 1 bits in System Platform that are read by KepServer, and for some reason other bits are going down to zero...
3,468
I have nuisance alarm that comes and goes. Doesn't seem to stay longer for a few seconds, is there any way I can somehow add a time delay or...
1,507
Hello. I have an existing Wonderware system connected to existing SLC500 PLC /Flow Computers / RTU as shown in the attached Pic. And Existing...
1,694
I have ControlLogix L71 on ethernet. I want to send data to another Third party device using Kepserver. DO you have any idea how much data can I...
2,457
