KepServerEX - SLC Addressing Vs. ControlLogix
Tanquen
Jul 2014
CA
163
We are updating A few older Aveva Wonderware InTouch applications from a SLC PLC to a new ControlLogix PLC.
What is the best way to deal with the different item/address format?
Issue #1:
B25:3/9 will become B25[3].9
For this I did a clunky search & replace in Excel, to replace the ":" with "[" and the "/" with a "].". This seems to have worked but concerned about selecting all and just the addresses in the CSV database dump.
Issue #2:
If the HMI needs to write to a PLC address you must add an @data type suffix to the item/address in the InTouch database.
"B25[3].9" will become "B25[3].9 @Boolean"
For this I again used some clunky search & replace and some VBA in Excel, to find the tags that are used to write values in the InTouch app printed to text file. Auto filtered for "Type: Input -", "Type: Push Button -" and "=", to make a list of tags that write out of the HMI and then add the @ data type suffix.
This works but could leave out some tags and is time consuming. Is there any reason not to just add the @ data type suffix to all tags?
Someone had said they thought that KepServerEX could import a tag list from the PLC and then you would not need to add the @ data type suffix to the InTouch database.
I was just following what had been done in other conversions. They have no tags added to KepServerEX and only added the @ data type suffix to some of the tags.
Hmm...
It looks like the command bit tags work with or without adding " @Boolean".
So just the analogs needs the " @Float" or " @ Short" added on. ???
It looks like the discrete tags will also need the " @Boolean" data type suffix if they are converted to descriptive ControlLogix addresses.
So if the old address for the Pump Start CMD was B25[3].9, you can read and write to that address through KEPServerEX without the " @Boolean" data type suffix as it knows what it is.
But if you change it in the PLC from B25[3].9 to an addresses of Pump1_Start_CMD, then you will again need to add the " @Boolean" data type suffix.
Does anyone know if it's possible, or the best way to go about adding a generic/ placeholder/ empty/ dummy tag to kepware? I used auto tag...
1,447
I'm working on a system with around 12 Channels and different PLCs with different KEPServerEX drivers. We converted a PLC program to run on a...
17
2,973
I've setup another VM with KEPServerEX but it will not talk to the same PLC that the other is. It is seeing the PLC as it will show another error...
2,451
KepserverEx v6.11.718.0 Studio 5000 v33.00 Has anyone ever run into an issue with adding strings (that are part of a UDT) into Kepware? In other...
1,907
I am trying to find PLC simulation software that will connect with KepServerEx, in order to learn and test an OPC UA solution. My Siemens trial...
1,417
