Kepserverse to dh485 through netaic
firehose
Jan 2007
Farmington, NM
I have an installation of 4 ml1200's and a PC running Kepware's OPC Server and am having problems with the communication between the PLC's and the server. I have 1761netaics for each ml and they are talking nicely to each other. I can talk rs232 DF1 directly to my mls and the server works great, but when I plug the server into the netaic, the server start logging errors that the Kepware Tech Support guru said were framing errors. I have tried adjusting multiple things around this connection. Also, I am using a usb to serial port converter from Black Box and all port speeds are the same on each device. I just don't have a clue where to go from here. I can add the data movement to one plc and therefore bypass the need for the pc to talk to the 485 network that makes comms to all plcs dependent on the single unit, and I would rather not.
Thanks for any help
Aaron
there is networking optain in the Df1 protocal after networking the four plc using Net-AIC you should use 1770-KF3 module to convert the DH485 to DF1
Note:-
Net-AIC is not a protocal convertor,
Hello all, i have seen a few things here and there about connecting to a panelview 550, however i still would like to ask a few things, I have...
139
Hi all, I had a setup with 2 Micrologix 1100 connected to a Panelview C300 over DH-485. I was mandated to upgrade the HMI, and proposed to...
903
Hello, We have an older machine that has a standard PanelView (2711-T10C3) connected over DH485 to a SLC 5/04 PLC via a 1761-NET-AIC module in...
684
Hi, I have a SLC5/03 connected to a working HMI via RE232 port, and connected to a broken HMI via DH485 (RJ45), I want to use the cable that used...
3,326
Hey all, long time reader but first time poster here. I've been tasked with an odd one and was wondering if anyone else had experience in this...
17
5,359
