Kepware write array
averellen
Jan 2004
Guelph
112
If anyone has an example of writing an array through the AB driver using kepware I would forever be gratefull.
I have 4 lookup tables with 30 strings in each, each one starting at a loction multiple of 5. First I tried ST file, but ran out of space before I even got started. Figured I could do a search in an ASCII file for what I need. But I also want an operator to be able to update the tables via VB app on their desktop. To assign a tag for each ASCII file would be suicide.
Be easy to build the array and dump it into the correct table.
Reading an array was easy. Writing has been a pain.
Hopefully I'm being clear in my thinking.
Edit.... I'm am using VB6
Adam
I think I might have it figured out. Kepware, or I guess any OPC server will let you pull a string value from an ASCII table. So anyway my tag just pulls all the data in the ASCII Table with a serperator. When the client app makes the change I would send in the data with the same seperators.
Tag looks like A231:0/256
Adam
I have a strange Kepware issue I have been dealing with for a few weeks. I have Kepware setup with the Omron NJ Ethernet driver and reading in...
112
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
180
Im trying to get data from AB guardlogix controller using Kepware in a remote location but it seems that version 6 can only support contrologix...
453
Hi, Have anyone came across issue with Kepware or Linkmaster not returning correct values (Unknown Quality) for some tags From OPC DA Client...
699
I’m attempting to configure KEPWare to poll a Modbus device via Modbus TCP/IP. However, everything I’ve tried results in an error being reported...
436
