Kinetix 300
don2405
Jan 2014
Port of Spain
33
I have a Kinetix 300 servo, it logs on to the motionview web interface but when I click connect, it stalls,nothing happens, no connection. Is there a problem with the drive?
See attached pic.
Hi alan_505. I tried different versions of Java with the Kinetix 300 drive and same result.I then tried another Kinetix with the same web browser & java and it worked.
Any suggestions?
Try downloading the MotionView from the same exact drive.
Sometimes different drives can have different versions that may not be compatible.
Use a Web browser and enter the IP address of the drive.
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
153
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
231
Hello. I have a few machines that use Kinetix 300 (each machine has two drives). Both drives on one of the machine keep losing IP address. They...
104
Hello, We have had a machine running for the last 10 years. It has 2 x Kinetix 300 drives. Around a year ago, one of the drives failed. We were...
432
Hello, I have a die punch machine with servo motor for material feeding. I'm using Kinetix 5300 to control the feeding system. Every recipe have...
529
