Kinetix 5100
Joe Loescher
Mar 2003
Brampton, Ontario
47
I need some help with setting up the homing and indexing of these drives.
We are upgrading one of our lines that was using ultra 3000 drives to the new kinetix 5100 drives. there are 8 drives and servos on the line. There are 4 that do motion and 4 that use indexing.
The motion part was pretty easy to set up. however getting the indexing drives set up is proving to be a PIA.
The first issue is the homing. I am trying to home to a sensor, and cannot get the motor to stop on the sensor. It always passes the sensor and by a different amount, depending on where it starts homing from. I have slowed the homing down a lot, but it still passes the sensor. I have also tried every homing type available...all 38 that are available. I have played with the accel and decel speed I even tried moving the home sensor to a high speed input, nothing seems to help. Looking for any suggestions as to what to try next.
Hi, Again, a topic about Kinetix 5100 servo drives. The controller is L33ER. The servo drive are 2198-E1020-ERS with a TLP-115-200-DJMC2A. There...
561
Hello, I'm in the process of converting a slicer from an Ultra3000 drive to a Kinetix 5100 using the KNX software version 4.00. The current...
535
Hi, I have a project where one of the modules is a gantry type structure with 2 servo motor, one from each side of the gantry. The transmission...
1,735
There is a new Micro 850E that allows you to do implicit messaging to a Kinetix 5100 servo and a Powerflex 525. I can't seem to find any...
1,963
Im teaching mechatronics in a community college. We were advised to get into Servo drives and the 5100. We downloaded and ran KNX5100C and it...
3,845
