Kintex350 noob question
dwoodlock
Nov 2012
Cincy/nKY
568
Gents,
So I am reading through the manual for this drive, and it sounds to me like I can only use this drive in combination with a logix controller?
Not an AB guy, and paying for support for hardware you just paid plenty of dollars for is a joke, can someone confirm or deny?
Thanks in advance
Gents,
Thanks in advance
Correct, The 350 series only works w/ the motion capable Compact and ControlLogix processors.
Additionally, I think the older 1756-enbt's don't work either, need a newer 1756-en2t or 2tr, or 3tr.
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/2097-um002_-en-p.pdf
I don't know what you're using for a control platform, but the Kinetix 3's can be controlled by the micrologix family.
Thanks for the info, I just sent an email to my local AB vendor, seems like a micro will do the trick.
Have a trial coming up, and we had Kinetix spares in house for another machine. My plan was to use the spares to run the quick trial, as I thought I could make it happen without spending a bunch of money.
I shouldn't have assumed.
Simple application, using a crude Omron cam controller. 3 differing setpoints during a 360deg rotation. Accelerate->Coast->Hold->repeat
Thanks for the input.
I work in a field where our plc and hmi are constantly being powered fully off and on daily before being sent out. I am new to the world of plc...
964
Please laugh… but can I take 24volts from an IO module and wire it straight into its own input card to simulate an input….?
1,265
I need to be able to open a customer's FT View project and make any changes if necessary. Which one do I need??? :hmmm: I don't want to have...
2,594
Hello all, i will start off by saying i know nothing about load cells, i want a converter/amplifier to output a 4/20mA signal from a load cell...
5,405
Hi All, I don't have a ton of experience with PLCs yet, so I appreciate any feedback I can get. What I am doing is using an Omega FMA1816A mass...
1,827
