Klockner Moeller PS306
Johnny Rotten
Dec 2004
Ontario, Canada
194
Hey everyone, have an issue with a machine that has one of the above installed in it. Have no programming software or cables. The PLC stays in 'Halt' mode regardless of what I try. The 'Ready' and 'Run' indicator lights are not on. One 3 position switch is 'm-reset', 'Run', and 'Halt'. The other switch is just a reset button.
And it does not go to Run if I put the switch to 'Run'.
Sorta stuck and could use some help, thanks as always.
John
Master Electrician
First 'Ready' means power supply okay,if not on means power supply not okay after that 'Run' must be on if program is in plc
Regards
Bajram
Ok, so I have no 'ready' light. Assuming my battery back up has kept the program intact, I can replace the power supply? The 'run' light is off as well.
Any idea where to get one?
Thank you.
John
I am looking for leads on getting a manual in English for the Klockner Moeller VTP HMI software. The software is VTP and was DOS based. From what...
565
Hi I have a customer who has come to me with an issue with his Klockner-Moeller PS31 PLC. I realize its pretty ancient and should be replaced, and...
2,314
Hi. I have a program that is from 1988. It is written in IL and I cannot find manual for it. It is PS32 PLC. On vendor site...
1,560
One of my customers purchased a used machine with a Klockner Moeller PS4-201-MM1 PLC in it. The program was gone, but they were able to obtain the...
3,363
I am trying to track down the hardware and software to get online with an installed Klockner Moeller PS3-DC PLC. I wish to gain the means to get...
2,384
