KOYO PLC with IFIX Software
Ramsri
Apr 2014
coimbatore
40
I hav Koyo 250-1 Cpu and it needs to be integerated wit IFIX scada by rs422 comm. I have introduced rs422 to usb converter for data fetching. Is it needed for inverting R+,T+ signals at Converter Rs422 input side? Suggest.
I think your question is about a four wire RS-485. The transmit on one device must connect to the receive on the other device, and + to + and - to -. Both the 250 CU and your other device should have wiring diagrams.
Tom is correct. You need to check the wiring diagrams.
Getting USB to serial devices to work correctly can be a problem. This is mainly due to the 'Recommended Standard' on RS232, RS422, RS485 and power supply. Do you have another device that you can check this converter to see if it works?
I have had allot of luck with the Sabrent devices.
This article will explain a little about serial connections:
http://accautomation.ca/heres-a-quick-way-to-connect-rs232-equipment/
Regards,
Garry
http://www.accautomation.ca
Hey, I am entirely new to PLC's and am trying to help my friend with a project. He wants to take the signal from a PNP photoelectric sensor as...
2,249
Hi all ! I can't figure out how to setup the modbus RTU comm. to connect a Koyo DL250-1 CPU with a Panelview Plus 600 from Allen-Bradley. I use...
3,978
I was wondering what my best option is for an upcoming project. I have an exsisting DirectSoft 205 PLC with a D2-250-1 CPU. I will need to control...
2,921
Hello all, I am a recent graduate at my first job tasked with a PLC project. I need to control a linear actuator given feedback from several...
2,161
Hey guys, I have one of the new CLICK plc from AD with an ethernet port on it. I made a subroutine for an IO Map of a modbus slave device I have...
4,706
