KTX(D) in XP Mode???
arkansascontrols
Jan 2008
Arkansas
112
Anyone have any luck getting a PCI KTX(D) card to work in XP Mode Virtual Machine under W7?
Upgraded a PC, got FTView, Logix, and Linx installed and working in XP Mode, but need to communicate to the DH+ network through the KT Card. Win7 sees the card but clearly I don't drivers for Win7
XPMode see's one unidentified device listed as a "Virtual PC Integration Device", which I'm assuming is the KT card, but of course XP drivers won't install.
There has to be a work around for this. Anyone got any ideas?
after some trial and error here is what I have learned.
2.57 Drivers for the KTX do indeed work in Windows7 64Bit, and the OS recognizes the KT card. However, if you have software compatibility issues that prevent you from running your applications (FTView SE 5.1.00 for example) under W7 there is not an easy solution. VM's such as XPMode and VirtualBox don't virtualize the PCI bus so legacy hardware on the PCI bus isn't going to work inside the VM guest.
If you happen to have an activation for RSLinx Gateway. You can install this activation under windows7, configure your gateway, and then run Linx Lite inside the VM and connect 'remotely' to your DH+ network. WHAT A KLUDGE! but it does work.
Of course the USB DH+ adapter from AB works fine with W7 and USB devices will work inside the VM so I wouldn't recommend the above solution unless you already have a KT card and an RSLinx Gateway activation.
It's not really a kludge. It's just a limitation of the VM. They can't/don't recognize PCMCIA, ISA, PCI, or PCI-E buses. I have always had good luck with USB though.
OG
Although FTView 5.1 is not supported in Windows7, it does work. I have 5.0,5.1,6.0, and 6.1 FTView in Windows7 VM's. x86 64 bit is not supported until 6.1.
I have used these VM's for some time now.
RSL
Hello to all, Recently purchased win7 pro 32 bit machine, install with AB PKTX(D) PCI communication card and want it to run under WIN XP MODE...
3,144
Hey everyone, Ran into an issue on a customer's system a couple times recently and wanted to check if anyone might have any clue what's going on...
1,400
I have and old computer running controlview300 in dos. I’m try to update to rsview32. But the question I have now is getting communication...
2,790
Has anyone tried using a 1784-PKTX in a PCIe slot, using a PCIe to PCI adapter? :scratch:
1,374
Hi, Previously we used SS5136SD DH+ cards for communicating with Allen Bradley SLC 5/04 PLC utilizing Wonderware free SST5136 DDE server. This...
2,851
