Kuka robot FB or FC STEP7
Casius
Jan 2014
Cluj-Napoca
Hello,
I have a new project with a kuka robot. Does someone have to share a FB/FC in Step 7 to start and command a KUKA Robot? If is possible in english or french.
Thank you
Hi Mark
Is ok in TIA, I will write in S7. I want to understand the logic. I know the signals for external (move_enable, drives_on, conf_mess,peri_rdy, etc..) but I want to see how they are used to have no bugs in the function.
If it's possible pls send me a project.
[email protected]
Thank you.
Hi Mark,
I have a similar issue, I'm trying to get Kuka robot to work with siemens PLC.
I've tried to make a FB for the start up and control, but it would be helpfull to see a working FB or FC, to see what I'm doing wrong. So could you please share your project with Me?
Thanks,
Pasi
pasheino(at)yahoo.com
Hi all, First time posting here. I have a Omron NX1P2-1040DT controller that I intend to use for a small project. I also have a KUKA robot that...
1,205
Hello, I need to establish a CIP safety communication to a KUKA KRC4 robot. The KUKA has the IP 192.168.11.53. I already established a standard...
10,292
Hello, I have to communicate with a KUKA robot (Type KRC4 with EthernetIP Interface). For that I use the Generic Ethernet Module with the...
6,825
Hi, I'm working in a project in which I need to put 2 kuka robots as slaves in a profibus dp network. The master is a wago ipc plc. My problem...
4,270
Does anyone know the maximum length of the control cabinet cables (as supplied not self made) to the robot on a KUKA Robot (KR 40 PA) ? My KUKA...
4,579
