L32E and Controlflash Plus Problem
Duranthas
Jul 2008
Southeast Missouri
132
I have a 1769-L32E "A" model that I am trying to flash from v19 to v20. When using Controlflash Plus, I am logged into the Download Center and I correctly select that I want the latest firmware from the download center. After it downloads and I get all that squared away, when I go to actually install the firmware I get the error "Revision downloaded is not compatible with this device's hardware series. Choose a revision that is compatible." So to make sure everything is kosher, I went under the manage firmware tab, deleted the 1769-L32E firmware, then re-downloaded the firmware from Rockwell. I tried direct download and managed download, but each time I get the same error. Rockwell won't let me download any v20 below 20.19 and for some reason it believes the v20.19 is incompatible with my processor. Has anyone else ran into this?
Interestingly enough, if I use RSLogix 5000, and go to Communications/Who Active/ and select the processor then click Update Firmware, I can browse to the 20.19 "A" dmk I downloaded from Rockwell. It just seems odd that I can't do that with Controlflash Plus and I kind of want to understand why.
All, I have a system on a CompactLogix L32E with Devicenet. I need to flash the 1769-SDN Devicenet module to a higher rev. after flashing up the...
1,253
I just found two old 1769-L32E controllers in the plant that I cannot go online with using my version of Studio 5000 (30.14). I've reached out to...
2,037
Has anyone experienced the following issue on RSLogix5000 (currently on V16) I have a PLC program that has been running on a site for a number...
1,621
Hello; We have an Allen Bradley compact logic processor at an auto glue kitchen of corrugator machine which connected with AB HMI. Normally to...
2,445
Im on site, there was water damage in the cabinet. Trying to see what i can do Right now here is there. I can see all inputs, and LEDs work...
2,600
