.L5X files (Help me understand them)
theColonel26
Feb 2014
West Michigan
785
OK, so am wanting to move 100+ tags into a new UDT.
I figured the easiest way to do this is to
copy and paste the tags into excel.
Then create a new UDT export that to .L5X
Then using the format for the <member> XML tags
transform the tag names and types and insert them into the members tag. So
Code:
   JugA_CamStartPulse   BOOL
gets transformed to
Code:
    _CamStartPulse   BOOL
I stripped off the prefix. of "JugA"
and then to
<Member Name="_CamStartPulse" DataType="_CamStartPulse" Dimension="0" Radix="Decimal" Hidden="false" ExternalAccess="Read/Write"/>
However in my play around I have found this curious
in the first 2 lines of the <members> tag there are these lines
Code:
<Member Name="ZZZZZZZZZZTest1" DataType="SINT" Dimension="0" Radix="Decimal" Hidden="true" ExternalAccess="Read/Write"/>
<Member Name="theBOOL" DataType="BIT" Dimension="0" Radix="Decimal" Hidden="false" Target="ZZZZZZZZZZTest1" BitNumber="0" ExternalAccess="Read/Write"/>
What is the first row for? Is it a place holder for the name of the Instance of the UDT??? and why does the BIT/BOOL underneath it have a Target="ZZZZZZZZZZTest1" attribute?
dmroeder I'm glad you linked that, I was about to go ahead and retype something very similar, almost as if I have played with these before!
I was about to type something up too, then I thought, someone has probably already done this... sure enough!
Hello PLCS.net! Trying to run some scripts on l5x file, does anyone have some file they can share with me? Thanks! -PreLC
1,882
I am trying to automate code dev for VFDs and I was looking at the L5X for a VFD, I am wondering how to parse the cdata. Below is a small snippet...
846
I'm trying to save a project as an L5X and I need to uncheck the "Encode Source Protected Content" checkbox, but it's grayed out. How do I get...
944
as already mentioned in the title, document 1756-rm014_-en-p.pdf mentions a limit of decorated data (XML format) to 100k. Is there a way to...
612
There is a requirement to convert some projects back to Rslogix 5k , I want to check if I can convert version 30 AOIs to version 20 AOIs. Thanks
1,048
