ladder control with pc (HMI)
jalil
Jun 2006
jeddah
hi
how i can control a ladder circut with pc (HMI).EXample
i write x01 ----NO, Y01 -----NO , when i give a physical input to x01 then y01 will energise. wat i have to write a ladder to activate y01 from pc usinng SCADA .
rgads
jalil
It is called indirect addressing. In AB world you would use bit or integer file location, to control or display on your HMI.
Nitpick - That isn't indirect addressing.
Indirect addressing is when you use the contents of one memory location as a pointer to the ultimate target. Using PLC Internal bits/memory locations is a normal, standard addressing mode. B3:0/1 is always B3:0/1 (AB 'Classic' Example).
Indirection would take an address like 'B3:[N7:1]/1', and would refer to bit one in whatever word in the B3: file that was contained in N7:1. If N7:1 were 18, the result would be the value of the bit in B3:18/1.
"Hello, I am a beginner learning about PLC. Could you please give me some advice? I want to write PLC instructions as follows: When the sensor...
18
3,467
Old Allen Bradley guy here: I used to have a SCL or SCP and then a PID tuner block to use. Here in the FANUC ladder world I have not been able to...
1,900
Hello Everyone, I would like to get some advice from seniors!! Currently, I involve in writing PLC logic and Robot programs (ABB rapid...
3,912
i need to control six pump sets. initially 2 pump sets will run after two hours another two will run and later the third pair. 5 bar pressure...
26
13,649
Hi All, I'm fairly experienced in Allen Bradley PLC programming but have come up against a problem I've not encountered before and wondered if...
8,418
