Learning PLCs .... relatively quickly
I will offer a small bit of advice when it comes to panels. All devices will require spacing to separate them. If the panel is going to have multiple drives or large starters make allowances for 2 to 4 inches (50 to 100mm approx), this is just basic the dimensions could be more or less it just depends. The specifications for the device will state spacing needed.
You can see a basic layout at:
http://www.patchn.com/panel_layout.htm
Most companies have 2D and sometimes 3D cad drawings, one enclosure/panel company is Hoffman: http://www.hoffmanonline.com/Product_Info/
Attached is a list of device designations..ie abbreviations used for many devices. Sorry about the quality of the print.
You may also want to determine what codes must be followed when building panels and get the applicable books. IEC, CEC, NEC???
E
Even though it was briefly mentioned, I feel that the proper place to start is to understand the safety aspects of the machine and or installation. The first order of business should not be if I can make the machine do A or B, it should be to NOT hurt anyone. There are some good threads in here about risk assesment and I would start there. As for panel building, NFPA 70E Arc Flash is getting all the attention now. Any new panels I design will be keeping 120 VAC 480 VAC and 24 VDC separate. Ron's site (http://www.patchn.com) has a lot of good stuff, it would definitely take more that a couple of days to grasp some of his information. Read some information of safety equipment manufacturer's, there is some good things to learn. Also understand that 120 can and does kill. Please approach everything with "guarded enthusiasm". Elevmike recently had a close call in a panel due to a small moment of inattention, there is a thread on that here. Hope you do well in all your future projects and enjoy the programming - think of it as a challenge, not a job.
I forgot to mention one thing that is a personal pet peeve. Its so aggrevating when you have to go into a large panel to troubleshoot but you have to lay/sit on the floor to access the terminal strip.
It's good to see that everyone on here seems very safety oriented and is making sure I understand the most important stuff @ hand, that being safety. Rest assured, I am a very safe person in general. This was instilled into me by my father who was a construction guy / mechanic his whole life and has a few safety related scars from almost fatal errors that were made primarily due to poor designs of equipment (damned bobcat pressure release safeties). Noting that, I also worked with a twin to my dad (another old-europe manual laborer) who didn't quite have the safety knowhow as my dad and his visible damage to his body is extensive; not something I want for anyone. I enjoy the operation of all my fingers and appendages and now realize that there exist operators JUST LIKE HIM who are willing to put their safety on the line and will go out of their way to make a safe thing unsafe in some way. I realized that people like him will be using machines that I build ... that's scary. I don't even want to get into the stupid things this guy does on a regular basis dispite my pleading.
Eric Nelson said:
Also, be sure to read THIS article at mrplc.com by Jim Rowell. Excellent set of guidelines to follow...
Addressing both quotes now, I read that article once so far and have saved it in my library of useful stuff off this site; my archive is starting to get big enough to require reorganization into more detailed subcategories. I never really thought about the whole pinching to ground issues or theoretically having a wire 'fall off'; I am VERY happy to have read that article. Other things like how to wire specific safety devices make no sense to me right now so reading those sections doesn't sink in yet ... hence the saving for future reference.
Ken Moore said:
PERFECT, now I am going to search for the 'bad panels' thread ... a little comic relief is in order I think. I wish I tokk pictures of the decommissioned panels at the WWTP I worked for; if the current EE guy didn't design it, then they were total ****. I scoffed a ton of practice wire off those old panels, and got to see what happens to a wooden electrical panel in a WWTP; not good.
Jim Rowell's article mentions this :) My current panel I am building will have this problem; I will see if I can fix it (read: Unlikely)
It's actually getting a lot more fun now that I am seeing all the cool things that I will theoretically be doing soon.
Ok, and JUST IN CASE anyone thinks that I am going commando on these projects, I am not (yet anyways). Most of the current projects that we are working on have already had all their controls quoted and panels designed, etc. These projects are intended for me to learn off of hence wh I wanted to know basically how to progress. I want to be able to gain as much "CORRECT" knowledge from these projects before they are installed and I won't have access to them (at least, not their PLCs or control panels).
Thanks for all the info, these links are amazing.
I want to pick up an Allen Bradley PLC so I can practice writing programs. I have 10 years as a maintenance tech and a good understanding of...
265
As someone who's learning about PLCs (just for fun at this point), I follow the various threads posted by other beginners, and have been wondering...
3,688
Hi I am looking some advise on where to start learning about Siemens s5+s7 (monitoring,programming and fault finding) My only plc experience is...
19
4,773
I was wondering how difficult it would be to learn Delta V systems coming from a PLC background? I've worked primarily with PLC 5 and CLX...
3,821
I am the "electronics guy" in the maintenance department at a sardine cannery. I have been to a 3 day course on "PLCs for the Non-programmer"...
32
19,861
