LED in PLC 135u-CPU 928B
mehrdad76ir
Feb 2004
IRAN
Hello Dears,
I have 2 question and hope u would be help me,
1st I want to know the working of the led in CPU 928B card on PLC 135U, and I want to know when LED flash slow or fast what happend and what must we do.
2nd we have 2 PLC 135U-CPU 928B and one of them have too many block (about 250 ) and when we want to stop and start, after overall Reset when we r in stop mode we transfer data to PLC,and after when we want to start,PLC doent go to start and RED flashing LED is appeared.
so now we start plc without any data and the last for executing OBs we reastart and then start only cold restart.
what do u think about this problem? may u help me.
beforehand many thanks from all.
bye
MEHRDAD
Flashing slowly:
The CPU is in the "STOP" mode.
The CPU itself prompte the "STOP" mode (possibly also of the other CPUs).
Typical causes:
ADF,QVZ,LZF,BCF, controller error, interrupt collision, cycle fault, BSTACK overflow, ISTACK overflow, stop command, end of program test.
If you switch the mode selector to "STOP", the flashings stops and the LED is lit continuously.
Flashing quickly:
An overall reset has been requested. This request can be generated by the CPU itself or also by on operator input.
Try find manual 6ES5998-2UL22 for 928B
On this project, the operator's asked me to add an LED onto the cabinet of the PLC enclosure, such that the LED illuminates when the PLC's...
1,066
Hi, I have an ABB AC500 PM-582 PLC, The question is... is it possible to get the compiled code out of the CPU, i need to have this as a backup...
1,500
hi everyone i have this simple program using HSC i set the NEW_RV to 1000 when rotating the encoder and when reaching 1000 the counting restart...
1,581
My boss has come up with the idea of renting machines and charging on a per use / per hour basis, so I'm looking into it - just getting my feet...
4,000
Hi In one of our machine, there is Seimens PLC IM151-8 PN/Dp CPU. HMI is connected via Ethernet and other devices are connected via Profibus...
3,147
