Lenze 9300 POS and Siemens
userxyz
May 2002
any
2,768
I know too less about Lenze Positioning.
I have a new job where I have to finish a project of someone else. Everything works manually. I need to write the automatic cycle.
I have seen that he reads a statusword of the drive, the actual position and receives the actual program running in de Lenze.
On the bottem of this FB block he sends a controlword, a setpoint position and the program set.
Question I have, does anyone has experience with these lenzes, can you give some information, how you wrote it... ? I can see that he has to swap bytes and swap words
i also have somewhat limited experience with lenze but its important to know to what extent you are familiar with this drives ,cause it can be a little tricky to understand how it performs positioning cause in my case a controller just triggers different positionings by setting certain bits responsible for chosing programms of positioning inside drive. all the positioning drive perfoms itself. so your task consists of two: parameterization drive itself in certain way and programming a controller to define a positioning cycle- at which moment what positioning should take place.the communication in oder to do it is not the most difficult part. in my case i read manual SHB_9300_servo_position_controller_v3-0_EN which i got at their site there are many others but i dont remember the actual link sorry. you can reply if feel interested. i can reply only at weekends.
Hi All, I am currently working on a Simatic S5 upgrade to the S7-400. The currently installed configuration PLC is connected to 3 LENZE 9300...
3,347
I have a 9300 servo drive that I am trying to connect to with global drive connect software easy. I have connected to the drive with windows XP...
1,775
Hey Everyone, Does anyone know how to update the software version of a Lenze Inverter 9300 series? I would really appreciate it. I have two types...
2,513
Hello! For my BSc in automation I am attempting to communicate with Lenze Servo Positioning inverters (e.g EVS9329-EP) for motion control. I am...
3,264
Hi, I have a Lenze 9300 servo motor. I want to control it via CAN bus. I've implemented CAN protocol in FPGA and I send standard frame over bus...
4,638
