lenze communication
MAHER
Jul 2007
CAIRO
82
Hi all
it is first time for me to create the network consist of plc S7(315-2DP) and drive lenze (9300 vector).
but in the fact i haven't any information about the data transfering between the plc and drive to control on it.
please i want to learn the steps to make it and applications to demonstrate it for me.
best regards
maher
i mean by steps that
- how can i transfer the data between them to make the control on for example( enable for the drive ,speed ,direction ,...etc)
- the blocks which we need .
- i need to make full control on the parameters for the drive .
maher
I rememeber some Lenze drives I worked on years ago. They used Profibus to do what you are talking about. You should find in your drive manual (if the drive is profibus compatible) a list of drive parameters with there Profibus codes. The PLC you have listed has Profibus DP installed. Refer to the S7 PLC manual for details on how to setup the Profibus. The SIeemens web page has manuals you can download that will give more detail.
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
183
Hi All, I am having issues communicating between an Omron CJ2M PLC and a Lenze SMV Drive (with Ethernet Module). I have set up Network...
1,154
Hi I want to establish a connection between Lenze 8200 and s7-200 cpu 226 Using RS485 or in other words Modbus Please Help
2,279
Hi; To get communication with Lenze 9300 drives, we have arranged “PC System Bus Adapter” Type EMF2177IB. We have installed software “Easy...
3,649
Hi there, I have a Lenze C300, P300 & Top Line 8400. I have a basic application which only requires the drive to follow an external encoder...
2,412
