conradstone
Gentleman, this is not a PLC problem I think but a Drive issue. I am running Controllogix L85 connected to a Leroy Somers\ Unidrive M702 on Ethernet IP. The motor is showing 825 amps when the load at other plants on same machine is 400 amps. We are the 4th plant to have the equipment installed. They have told me only the Leroy Somers guy from Europe can fix this problem because we do not have the expertise. I have never worked on this drive before, but a PLC is a PLC, a drive is a drive.
Has anyone experienced this before? I will be connecting and downloading the program this afternoon and I can provide more information. They have told me ohh, he just changes one parameter, but you wouldn´t understand. I call malarkey. I have read this site many times and solved problems. I will try to add some pics of name plate for motor.
Thanks in Advance,
Thanks in Advance,
