LG Master K Distributor info ?
wrapitpkg
Sep 2008
Auburn
I have packaging machines that use the LG Master K 120S PLC.
I am new to PLC programming, but need to find out where some support is for these small plc's if possible.
I am wanting to get the programming program as well as the communications cable for my laptop, so I can do more than just service the electro-mechanical aspects of them.
Can anyone tell me where a distributor for these units can be contacted ...
I appreciate yoiur assistance.
Mike
Thank you for your post.
I just need to know which software to download since there are a few...so if you can tell me which one I would appreciate it.
I saw the manual was there for downloading too.
Thanks,
Mike
I believe you will need GLOFA
Check with LG industrial web site.
Use google.
Make sure the GLOFA is compatible, I'm going from memory here.
Used it once for a test, never actually used for a real life application.
It was free at the time (the software) not usre if it is nowadays.
Hope this helps
I gambled before your last post and downloaded the KG Win 365 program instead, and it was the LG program. I downloaded the program file from the manufacturer and it loaded into it and works.
Thanks to everyone that assisted me, I appreciate your help.
MIke
150
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
96
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
79
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
279
