LIDAR SENSOR - with Field bus for PLC
mad4x4
Mar 2009
ST CYrus
363
Looking for a LIDAR sensor (2d) that we can use with a Siemens PLC for measurement, Would like to interface directly with 4-20mA or a Field bus protocol (Profinet/Profibus) Who has used what.
Lidar need to detect and measure distance to a 76mm metal object which moves is a vertical plane (XZ) and could be up to 5 m from the face of the lidar
'2D' implies that you want a sensor that can detect a profile.
But what you describe appears to be a laser distance sensor (arguably '1D').
Which one is it ?
No will need to be 2D as the object and move up and down (z axis) and also closer and away from sensor (x axis) .
it is the measurement of the Distance from the sensor we need (x Axis)
Let's leave the semantic question of 1D vs. 2D alone for a bit (although I agree with @JesperMP based on what we know so far).
Please permit me to pull some teeth here:
This 3" metal object that is up to 16'+ from the sensor in/along the X dimension/axis: does its position in/along the Z dimension/axis exceed a range of 3" (76mm)?
You say it is the X position measurement that you need; does that mean the PLC already "knows" the Z position of the object at any given time?
What controls the Z position of the object?
As far as I understand it now:
There is an object that can be anywhere in a plane.
The distance from a fixed spot in the same plane to the object is to be measured.
That does sound as a LIDAR.
Can I open a Port from a Siemens PLC to an ethernet device Device will be at 192.168.0.1 and I need to open port 2112 (Upd?) Then once the...
325
390
Hi looking to install a smaller less sophisticated PLC for fountain timing and also one analog pressure sensor which would be used to detect...
23
639
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
122
Maybe a stretch to call this a PLC question, but it does connect to a PLC input. I have two German switches: Sick WL9LG-3P2232 And a...
124
