Linking Global Objects Without Connections
shebang
Jun 2022
Pittsburgh, PA
Hello all,
I am using FactoryTalk View SE.
I am trying to link an element from a global object to a display. This display will have a specific connection that differs from other displays using this global object. Therefore, I need to link the global object on everything except it's connections. This seems simple enough, since in the global object defaults there is a selector for
Code:
LinkConnections default
* True
X False
37j4Zx8Ko4VYt7IBVZXlGduAst02ZNo60AWblhz6ckoJvIYn1AbkKx80SUIBZfAaPlAbkEQmaKi0AkrhlfaGJpACEgoQvBJi0VC9FCB49coHeSOhAMErIRYN1UsBglevfJA3EgoQvBJi0VC9FCB49coHeSOhwAN4S9hvL+++PoCa8mKJ6TSUFAhOgQfwGi5YAAfnDq1MCogr8BC8xrRkMik+m0aSAgEqMAfeAH2hpUkBKQUIXim5aLBOChC8OmWDfJFSgOCVkosG66QAwatTNsgXKQUIXim5aLBOCvwHv4oRZvEp3wgAAAAASUVORK5CYII=
Well, as you can see, I have it set to false. And yet, when I place this global object on a display, I have to break the link in order to change the tag connections. This setting does not seem to change anything at all about how the element behaves. Why is that?
Is the object a tag label, trend, or Button with an action other than Command?
If so you can't set up a separate connection.
Maybe you can setup the global objects to use #1, #2, etc
That way you can use it on several displays with different connections.
I attach a picture.
So I'm currently in the process of linking 2 1756-L72 processors to send alarms back and forth. One processor is rev 26.13 and the other is 32.11...
136
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
255
I have a Micro820, yes I know they are hated. I have a brand new Micro820 that I programmed with a Micro SD Card. Once I got it programmed, I...
907
Hi, Have very basic knowledge of PLC's. Wondering if someone can point me in the right direction. Our assembly equipment is being run off of...
1,208
Hi, I'm new to working with PLCs and I'm experiencing issues with my WAGO 750-8212 device. When I attempt to turn it on, the SYS LED (orange)...
959
