Load shedding Scheme
Sorav.Kumar
Sep 2011
Nashik
Dear all,
ill be doing load shedding project for the first time, anybody please provide the control philosophy involving in load shedding concepts.
Turn a circuit breaker off and you shed load.
Be more precise in what you ask. I have no idea what you want.
Under generator power? Time based? Load based? Priority based? You have not provided any usefull information. Does not matter what PLC you use - you need to define what you want to do.
I have programmed power stations - capacity control - load control - load shedding - very complex. I assume you are not heading there but you do not say.
What we need ot hear is
1. What kind of plant you are working in.
2. What kind of support MUST you keep running. Hospital MUST keep power to surgeries, and other patient life support. School may not need to worry about it.
3. What kind of power generation do you have?
4. You do NOT need a PLC to do this. On submarines when we lost AC source and switched to battery we stripped load by manually turning things off.
As Bob said we need more info.
Dan Bentler
I have severals Power Generators of different Sizes connected to more than 20 Loads. I'm reading the Load (MW) and Breaker Position for each...
4,968
We are doing load shedding for Refinery having 2 Gas turbine Generator(25 MW each) for critical loads and a Public grid supply (10 MW)for non...
3,624
hi, i have a project about load shedding system, I have to build a prototype to demonstrate the function of it by using PLC. i need to know how...
2,669
I am in arequiremnt of a PLC having following I/O counts. DI:348 DO:102 AI:125 I want to use this PLC for load shedding purpose, which will...
7,515
C
Hello, we are implementing a load shedding program using a PLC based system.We are using S7 314 C2PTP Siemens CPU. The basic structure is as...
7,482
Chandrashekhar
C
