Local display
cornbread
Feb 2007
madison, indiana
407
A bit off topic, but I have an application where I have AB PLC controlling a 753 drive. I've been asked to add a local display by the pushbutton station to show the drive hertz. Looking at 4-20 ma signal. Wondering what others have used in applications like this?
If your just looking to display 1 value from 1 analog signal, I have used these many times in the past. May be cheaper and easier than setting a HMI.
https://www.ia.omron.com/products/family/576/
BCS
Just googled the redlion cub4 and see that it is also just a panel display/readout....not very familiar with redlion so I thought it was a small HMI that was being suggested. (Obviously it is not)
The redlion product looks to be cheaper (less expensive) and will probably be more readily available than the omron I suggested.
Anything along these lines would work though, there are lots out there.
BCS
Redlion for the win....For single value displays I've used them for 20+ years and the ones I put in 20 years ago still working.
Is there a way to add a local message display to Studio 5000 View Designer? If its there, I’m not finding it. I have used them in older versions...
417
Hi all, One of my clients has a Hach sc200 measuring Nitrates (wastewater plant) and the 4-20mA loop works, but the local readout is just...
1,368
Existing Condition: Running SE Studio (FTAE 6.10) currently and have VFDs pulling last fault code via DataLink to a UDT. This value populates...
2,393
Hi there, I am new to the world of PLC/HMI programming, an i am trying to use a local message display to show what page i am on without me having...
3,473
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
49
