Logic controller using Hold on/push button
Mitshu
Jun 2018
Delhi
Hi.
I have a question which am not able to solve.
There are 3 outputs (O1,O2,O3) and 2 inputs (I1, I2)
And we have to control these using the hold on switch/push switch.
If I1 pressed then O1 should work
If I2 Pressed then O2 should work and O1 should switch off.
If I1 pressed again then O1 and O3 should work and O2 needs to be off.
table -
I1 I2 O1 O2 O3
1 0 1 0 0
0 1 0 1 0
1 0 1 0 1
Is there a way to create proportional logic for a control valve without using a PID function? I want to create a simple P controller without...
2,623
Does anyone know of a way to detect if someone is online with the controller in ControlLogix (from logic) I'm thinking that maybe there is a CIP...
391
Dear all, Currently i'm working with micrologic 1400 cpu and Temate G5 Controller. I plan to communicate micrologic with temate using...
403
I'm trying to connect for the first time to a Rx3I via Ethernet for the purpose of looking at the ladder logic and inputs/outputs while the...
2,627
Hello everyone, Adding a remote rack of cards to control logix, I've added the cards to the controller through the enbt module, and it creates...
2,115
