Logic module?
Nov 2007
Illinois
75
I am far from a regular user of the AB Panelview Plus. I have been looking at a parts list with a 2711P-RP logic module. I've found lots of info on ports, memory, etc, but I can't tell what the thing actually DOES or is used for.
Can someone enlighten me??:sick:
Hi Stein,
Your basic PV+ is two components, a display, and a logic module. I've never ordered just the logic module itself (even if one decided to **** out on me I'd probably just request that the whole unit be replaced).
So if you say that the display module is your computer monitor, the logic module is your actual PC.
Other way around
Hi Stein,
I think the intent of making them modular was so you could just replace the screen, not the logic module. The screen is the most likely component to be damaged. At any rate, I do agree, from a reliability standpoint, I have always just replaced both.
Greg
I have a used panelview I'm going to use for learning on, but its missing its power input terminal jack. Can anyone give me the type etc and even...
1,403
1,537
Hi Guys, I am working on developing a "best practices" method of writing logic so I am looking for advice and recommendations on...
1,596
hello all i am using siemens s7-200 plc and 4AI 2AO analog module i have a capacitor level transmitter in tank which have liquid in it so i want...
1,976
I am in the process of migrating a SLC to a CompactLogix. To aid this conversion I am using a AENTR to make the SLC a remote rack to the CL while...
4,073
