Logic Pro Files
Elijah58
Nov 2012
Aiken, SC
60
Just wondering, is there a way to export files created in Logic Pro to RSlogix 500, not needing to do this just wondering if I create one in LP can I get it to RSLOGIX without re writing?
No, LogixPro is a program developed by Bill Simpson (a member of this forum) and is not a Rockwell Software program, so it cannot use the same routines as used in RSLogix 500. The best you can do (and I do this all the time) is split your screen with both LogixPro and RSLogix loaded, and then copy-and-paste the rung comments from LogixPro into RSLogix. If your LogixPro program is well written, by copying the rung comments from LogixPro, you have half the battle won.
Where I used to work, the maintenance mgr had ab logix pro 500 and I had the standard version.
we had no issues with it. but if you use vb code in the program or other features specific to logix pro, you will have issues.
regards,
james
Hi all, I have a request from client as follows, There's one PID for Control valve which would be controlling on basis of temperature. One...
1,524
I've recently downloaded the trial version of LogixPro simulator and I'm starting to work through the exercises. I have a question on the Relay...
2,537
hi guys i am trying to program a silo but have too use counters can anybody help??? thanks its for a course i'm doing in college
2,736
Hello, I am on a project using Unity Pro S v6 and am trying to perform a time of day interrupt by reading the high and low bytes provided by the...
2,674
HI all, Question regarding a program in Versapro. BEar with me as I just do basic programming updates and troubleshooting. THis program is on a...
2,622
