Logix Emulate V30 -> V32
Oliver Micka
Oct 2015
Hlohovec
65
Hi, i have a problem with upgrading Logix 5000 emulator from V30 to V32.
When i open "Setup" i have a only one choice "customize" where i have list of products, at the Studio 5000 Emulate V32.00 i have yellow triangle with exclamation point where is write: Unable to upgrade Logix 5000 Emulate.. and nothing else. ( see pic )
PC: Win 10 - 64bit
Before a several hours back, i installed the Logix Emulate V30 and i didint had any problem with installation.
I have a "RsLogix 5000 Emulate" from V20 to V30 and i need V32.
Rockwell's Tech Note on this is a little unclear as to the cause. At first it indicates this is an issue on 32-bit systems. You stated you are using 64-bit, so that shouldn't be the issue.
Then they also say, if the user already has v20, v24, v28, or v30 or higher installed, the error will also appear when trying to install v30 or higher. So this would appear to be the case for you.
As sigmadelta also suggests, they say to uninstall v30 then reboot the computer. Then following the reboot, install the new version.
OG
I have installed Studio 5000 Professional version V36 a time ago and installed today Logix Emulate V36. I have a exsisting PLC program, but...
760
First post here. Software: Logix Designer 31.02.00 Professional (running as admin) PLC firmware: 31.011 (required by customer) Actual PLC...
2,693
Respected Members I try to install RSlogix Emulate Version 20.04.00 but the error occurs during the installation which is shown in the image...
973
How does one obtain and install Emulate for RS Studio 5000? Company has professional license and professional installed on VM. No emulate. I go...
5,854
Been a long time since using AB. Looking to emulate a Micrologix 1400 job before the hardware is available. Is there still an emulator available...
1,966
