[Logix] resetting TOT total and oldtotal
defcon.klaxon
Feb 2015
Far NorCal
616
Hi all,
I've been using the TOT instruction for totalizing flows wherever I've not had flowmeters with totalizer pulses. It works great and I have it set up to reset each night at midnight to provide daily flows; I then use OldTotal to display "yesterday's flow".
One thing I can't quite figure out, though, is how you'd go about resetting both the Total and OldTotal values simultaneously. The client wants to be able to reset the flow totalizers with a button in the HMI. To reset the Total is easy I just one-shot the ProgResetReq input; but how would I go about resetting the OldTotal? The only thing I can think of is sending two pulses to ProgResetReq, but that may be a bit of a pain. I tried overwriting the OldTotal value but the TOT block repopulates the tag, so it won't be that easy. I'm going to mess with this a bit, but was wondering if you guys had any suggestions.
XIC HMI_ResetTotals ONS BST OTE Total.ProgResetReq NXB OTE OldTotal.ProgResetReq BND
... ostensibly. You can break that across two rungs.
Hi JeremyM,
Thanks for the reply.
I'm a bit confused about what exactly you're suggesting, maybe because I'm not as familiar with the FBD TOT instruction. I don't see any reference to being able to reset the Total and OldTotal separately in the 1756-RM006 instruction reference manual so I'm not sure how this would work; also, the TOT instruction is in a function block diagram routine and the totalizer is a local parameter; how would I access it in a ladder logic rung?
Am I totally missing something here?
My mistake, I thought you had two TOTALIZERS at once.
Would something like this (or the equivalent ST logic) suffice?
Indeed, just one totalizer. I can totally see your approach if you thought I had two.
As for your code example, that very well may work! Very clever with the second one shot. I'll give that a try. Thanks!!
Hi, I recently installed 2 1783-NATR devices into two of our machines. The machines are pretty much identical, both having 1769- L24ER-QFC1B...
323
Hey! I'm looking for a way to reset a tag when the routine that sets the tag is disabled. For example: Routine 1 has the following If Tag1...
1,834
Hi all, I have an issue with 1756-L62S (revision 20.13) safety lock. We can't figure out who put safety lock on our project. Before I try...
1,046
2,466
See how in the fault log that the axis fault happens and then is cleared milliseconds after happening. There is no reset fault hardware button. A...
1,901
