Resetting a tag in Structured Text in Logix Designer
FelipeGarcia
Jan 2021
ON
Hey!
I'm looking for a way to reset a tag when the routine that sets the tag is disabled.
For example:
Routine 1 has the following
If Tag1 then
Tag2 := 1;
Else
Tag2 := 0;
End_if;
And while Routine 1 was enabled, Tag1 was 1 (true) so Tag2 was also 1 (true). However, if Routine 1 is disabled, Tag2 stays 1 (true).
Any way of resetting Tag2 while Routine 1 is disabled without explicitly resetting it outside of Routine 1? Am I missing something?
Thanks!
Yes, you are missing the fact that the controller responds to your demands.
As to your problem, I would do it explicitly if the routine is not being called ....
Hey!
Thank you for your answer!
I understand that the controller responds according to what it was demanded to do. But it's a good reminder for everybody, including myself...
I also understand that explicitly reset the tag outside the routine is an option. However, my question was different. And maybe not clear enough.
I was wondering if there is a way to set up controller parameters to "operate" for structured text the same way as it does for sequential function chart when the Last Scan of Active Step -> Automatic reset is selected and there is brackets around the assignment symbol for a tag in a nested SFC routine.
Thanks!
I think daba answered this on another thread recently: call Routine_1 on scans when enabling bit is EITHER {1} OR {has a 0-to-1 transition (i.e. a falling edge)}.
I realize that is not exactly what is being asked.
Your memory must be better than mine if I did !
And I've highlighted your typo : 1-to-0 transition, although tbf you did say "falling edge".
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
279
Hi, I recently installed 2 1783-NATR devices into two of our machines. The machines are pretty much identical, both having 1769- L24ER-QFC1B...
323
How is it going y'all? So We have had a pesky problem with an EH 300 flow meter. We are using EIP to reset the totalizer, and for some reason the...
871
MELSEQ "intelligent modules" configuration, programmatically resetting the CPU Hello. This is for the Mitsubishi experts, and thanks in advance...
1,096
Hi all, is there an easy way to reset a user defined shift register to 0? i have a data type containing 8 bools for an array of 10 and would like...
3,236
