Logix5000 String Type
mrmss
Aug 2005
Midlands - England
101
Hi all,
Hopefully a simple Q.
I am trying to read a string from Logix5000 as an OPC string point. currently trying to view it in RSView, but cant even see the string in RSLinx.
I have a tag of type STRING in Logix5000, I put in some text 'Boloc' under monitor tags, I then try and use the Data Monitor in RSLinx and I find my string. The Value, Radix and Type are all blank. I expand my string and find LEN contains correct length. Then my string is presented to me by decimal ascii character value. Data[0]=66,Data[1]=111,Data[2]=108 etc.
Meanwhile in RSView, I select a STRING type when I try and add the point to the tag database but when I browse to my STRING i made there is nothing in the right hand plane (no strings here mate). I can change it to Analogue and then I can point to an individual element and read its value.
So whats the best way of getting a string out of RSLogix and into an OPC string?
Ta very much.
Sorted
What I did was create an OPC string point, and just typed in the path to the string instead of browsing; [topic name]String_Name
simple as that!
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
428
Hello, I have a question on an OCR application I am doing. I am reading in 16 characters that come from a camera into the plc in its input words...
1,279
I'm currently working on an MES interface PLC which passes around a whole bunch of strings. A lot of these strings are really just to allow for an...
1,123
HI Guys So i am trying to write a real SINt or DINT value into a string tag. If in string browser I write it manually, no problem. But how can I...
5,971
Sorry I'm a rookie when it comes to working with strings in RSLogix5000 I have a barcode application where I'm trying to increment a barcode...
2,626
