Logix5000-Writing to status bits in PID instruction, how to?
muncie21
Aug 2004
I'm trying to change the status bit for "software manual" mode of a PID block in RS Logix5000. Getting invalid type error. What I'm doing now is trying to write a 1 or 0 in the specific (PID.CTL.26) register. Thoughts?
try using something like PID.SWM ...
hope this helps ...
Hi, I use Excel to write some routines and was wondering if it is possible to add rung comments when doing so? Excel function: ="MOV "&[@[Range...
2,561
Hi im trying to read/write from excel-rslogix. Sometimes works correctly but other times doesnt work and in excel cells i reg #DIV/0! or REF. I...
1,350
In RSLogix 500 each data file has a “check the box” for “Memory Module/Download” and the checked box prevents downloads from overwriting user set...
3,735
Hello, I'm currently writing a program that is meant to write values to a specific set of tags. However, when I have a .csv file containing...
7,099
This may be easy but I'm more familiar with 500's than 5000's. I want to write the time from a 500 to a 5000 to synchronize them. I messaged it...
2,191
